anon(5719825)
Retired Moderator
Standby of an iPhone is what I'm always trying to duplicate
You will never get that. The iPhone calculates usage even when the screen is off.
3.5 SOT was yesterday and I had 21% left which may go more than 4h SOT, right? Now I fixed some things and I listened some music, but I have some apps that are checking my GPS location every 15 minutes, I didn't do anything, today I have 4 hours and 37min with 18% left so I think that's okay?Hmmm... 3.5h is quite low for average usage. I suggest going to Power Saving -Power Saving Mode -Restrict Performance and tick CPU, ONLY CPU, that should bring down power usage a bit as even when the CPU is in power save it has plenty power. Also set your GPS to Power Save and maybe try disabling apps you don't use in Application Manager.
Not on todays batteries. I've used my phone till it shut off, put a new battery in it, recharged the old one and life continues. No damage to the battery if you use it till it shuts down.
i really doubt that.. i'm not too keen about letting the battery die. i would recharge at 10%.
Heres mines tmobile kit kat
11 hours of screen on time and still have 51% battery left? Must be using an extended battery (ex. ZeroLemon 10,000mAh?). There's no way that's possible with the stock 3200mAh battery.
it's original battery sir.
I get over 6 hours of SoT with 26 hours of total useI too can get over 5 hrs OST but only get less then ten hours standby. I doubt that people who are getting 5+ hrs are getting a full day of standby. I could do the same on KitKat as well but get less than a day with 5+ hrs.
Wow, impressive then! Is your screen brightness turned all the way down?
it's around 45%, i don't use auto brightness. it's ridiculous IMO.
