Galaxy note 4 battery issues
nahoku
3,300
Depends on what the problem is. The Note 4 forum has a lot of battery threads. You might visit it and read the posts.
Gbsa
280
Will factory reset help?
My note 4 was draining battery really fast, getting very warm. Battery stats showed android os and system were the ones draining battery. Did a factory reset, opted to manually set up the phone instead of installing apps from my last back up. Now the phone is running well again. No overhearing, decent battery life. 5 - 6 hours sot usually lasts 12 - 14 hours.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,673
4,821
113
Welcome to Android Central! Moved to the Note 4 forum.
It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
stevenharvi
