A
AC Question
ok guys i am running marshmallow, the phone is set to airplane mode as i haven't have a sim card. i did a stress test from stress cpu software from google play. in the start when every thing was normal, the cpu temp was 40c, i think this is because the temperature is 35c around. but as soon as i hit the stress button and wait for 5 seconds and stop the test, the cpu temperature jumps to 68, and then after more 5 seconds ( a total of 10 seconds) it turn 80c. then i turn the test off. only in 10 seconds, the temperatures turned from 42 to 80c. however, the cellphone doesn't feel hot, but the rise in temperature causes cpu to throttle down from 2500 to 1190 mhz. maybe is there a fault with the cell phone? also, the temperature stress cpu shows is the same as (tsens_tz_sensor0) the firsrt thermal sensor in cpu z.
