Power saving mode options for Verizon model?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I am looking for the option to fine tune the power savings like changing the screen resolution, etc.,but couldn't find it
In the notification panel, I can for example enable the mid option
However once selected, there is no option to customize the power savings. Tapping on more settings brings me to this
Going through settings - battery brings this up:
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Hm odd. Maybe Verizon tweaked them?
Below on my T-Mobile variant I can get to the battery screen, select mid or high, and then I can choose / customize what I want it to do before applying it.
vmmatty
120
//uploads.tapatalk-cdn.com/20160822/ccb99f1a7edad932958867cdaf21419d.jpg
Go to Settings and then Battery. That should let you choose MID and then Customize to tweak the resolution. I have the Verizon model and it works, though I haven't messed with changing the resolution yet.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Figured out the problem... It was something I disabled with pdp. I enabled everything but the power saving option changes didn't come back until I restated the phone
