Typing is difficult, tapping on apps are harder, scrolling through screens. Have to touch so much harder to get keys to work. I am wondering if I should take back to best buy for a redo
U gotta leave it face down with some weugght on it after install or it will do that. Try putting it face down for a couple hours with some weight on it to see if that helps.
Hello,
The Zagg and Bodyguardz, two of the biggest name brands in tempered glass protectors only offer edge adhesive for curved screens at the moment and this can be a BIG problem, heres why...
Gorilla glass displays on the large phablets that Samsung and others use has become so thin that when it is used on 6" +/- screens the face of the display actually has wavy high and low spots. Lay your Note 8 down flat with the display off and look at how distorted the surrounding room reflections look.
Now add a glass protector on top of your device display that measures .030 or more and also understand that these protectors with edge only adhesive may or may not lay flat across the entire surface of your devices display causing a space or gap between the device display and the underside of the protector.
This is why some are experiencing touch issues on their devices with edge only adhesive protectors.
Bodyguardz is supposedly releasing a full adhesive glass protector for the Note 8 soon, not sure about Zagg.
BEST BUY WARNING: Be careful. 3 returns/exchanges inside of a 1 year window and they decline your next return/exchange and ban you for a year from any further returns/exchanges. They use a third party company called The Retail Equation to track your purchases using your ID. Yes The Retail Equation is being sued by several at the moment including a class action suit. Just be careful, pay cash and give Best Buy NO personal information.
I purchased the Zagg glass protector on Thursday. Dropped my phone last night and it cracked and came off my phone. Saved my phones screen, so I guess it did its job. So I went to use the warranty, and they charge $10 for shipping! Wow. I might just go with the HD screen protector.
Just curious, what case is everyone using with this screen protector?
