Battery Drain on Note 9 suddenly
NIZMOZ44
1,137
I am hoping someone can help me figure out what is going on. I was getting 6 hours or more usage for screen on time, and now my battery is draining pretty fast on it's own. Here is my battery usage from today with very little use. Just 1 hour of screen usage. Android System seems to be the biggest issue. Any ideas what I can do with that?
When you got 6 hours of screen on time, was that with pretty much continuous use, or was that also with plenty of idle time mixed in?
Try look into bluetooth/NFC
I see that you use it, maybe the battery issues are there..
It could be a rogue app.
Perhaps put the phone in safe mode which turns off all your downloaded apps and leaves the stock ones alone which can help to determine if an app is causing this situation.
If it was a rogue app it would be showing up under the usage pic I posted.
That's if it's being reported correctly by the phone.
I mentioned Safe Mode as this is part of the Process of Elimination processes people use to self help diagnose.
Maybe a Samsung Experience Store or Service Centre will be able to help you further via a diagnostic on the phone.
Sadly we don't have one in 200 miles.
you guys can also go into settings,apps then storage clear cache on individual apps
PmGs
