SpookDroid
Ambassador
- Jul 14, 2011
- 20,022
- 1,529
- 113
Can you detail how you cleared that data? Did you just go through settings/apps/clear cache?
Yup, Settings/Apps/Show System Apps/ find Play Services and Play Store, clear cache/data there.
BUT it's worth noting that this was because I was having bad battery to begin with (getting worse battery life than my S9+ with similar daily usage and locations). IF you have good battery at some places but not at others (like B.Diddy says), then this might not do it and could be more related to signal strength and/or location services. I'd only go with my suggestion if the phone went from good to bad on a similar usage/location pattern as before.
