Galaxy Note 9 Bricked?? Help!
  • Thread starter Android Central Question
  • Start date
A
Hi,
I hope someone can help me. I managed to get locked out of my new galaxy note 9 and decided to try to flash fresh software onto it. I have flashed phones a few times before and never had an issue.
Whilst the software was flashing in Odin it seemed to get stuck and so I used the shortcut to exit download mode and unplugged the USB from my computer thinking I could just try again. Since I have just had the phone stuck on a loop of a blue screen "installing system update", followed by "no command" and then a black screen which I have attached a picture of. I have tried all combinations of keys with no hope of entering download or recovery mode. If I hold both volume up and down as well as power button I get to the samsung loading screen but then this simply loops and goes back to what I described before if I release the buttons.
I really hope someone can help as it seems I have bricked by new phone. Sorry if this isn't the right place to post but I'm a new member here.
Cheers in advance,
John
What's on the black screen:
#Reboot Recovery Cause is [BL: Recovery mode set by key]#
E: failed to mount/cache: Invalid argument
Support SINGLE-SKU
Block based OTA
Supported API: 3
'MANUAL MODE v1.0.0#
E:Failed to mount /cache:Invalid argument
E:Can't mount /cache/recovery/last_locale
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,583
6,171
113
Hi,
Cheers in advance,
John
Support SINGLE-SKU
Block based OTA
Supported API: 3
Can you get back into download mode ?
johnwick27
No thats the problem I cant get into download or recovery mode. Can't even turn off the phone it's just stuck looping unless I press volume up and down and power in which case I see the samsung loading screen but just goes back to looping after.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,583
6,171
113
Catch it when it goes to the Samsung screen hold volume down and power probably Bixby also before it restarts
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,583
6,171
113
which carrier you on and firmware you try loading ? and what was the old version u had prior to trying to do this?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,583
6,171
113
If your still having problem with this PM me I'll give you some advice .
tivativa
