A
Android Central Question
Hi,
I hope someone can help me. I managed to get locked out of my new galaxy note 9 and decided to try to flash fresh software onto it. I have flashed phones a few times before and never had an issue.
Whilst the software was flashing in Odin it seemed to get stuck and so I used the shortcut to exit download mode and unplugged the USB from my computer thinking I could just try again. Since I have just had the phone stuck on a loop of a blue screen "installing system update", followed by "no command" and then a black screen which I have attached a picture of. I have tried all combinations of keys with no hope of entering download or recovery mode. If I hold both volume up and down as well as power button I get to the samsung loading screen but then this simply loops and goes back to what I described before if I release the buttons.
I really hope someone can help as it seems I have bricked by new phone. Sorry if this isn't the right place to post but I'm a new member here.
Cheers in advance,
John
What's on the black screen:
#Reboot Recovery Cause is [BL: Recovery mode set by key]#
E: failed to mount/cache: Invalid argument
Support SINGLE-SKU
Block based OTA
Supported API: 3
'MANUAL MODE v1.0.0#
E:Failed to mount /cache:Invalid argument
E:Can't mount /cache/recovery/last_locale
Cheers in advance,
John
Support SINGLE-SKU
Block based OTA
Supported API: 3
