My phone is up for an upgrade, and im debating between the s6 and the edge. Im not sure what to do, i dont mind the size of either
I was debating that too until i tried a S6. The edges on the S6 even though it has 2 are not as usefull as the note edge. The edges on the S6 are barely edges compared to the note edge. If you do get a S6 get the UAG case cause this https://youtu.be/QozCc2wX85U yikes!
With a Note Edge you have everything. Why would one with a Note Edge even contemplate the S6E unless they just want a more dimunitve phone...or don't like have SD access...or don't like the idea of having a removable battery...or worry about having the very best device (Note Edge) and want something lesser (like the S6E)? ...just doesn't seem logical. Perhaps I need more coffee.I am not a fan of the S6 Edge since I have a Note Edge. The Edge in S6 is only for design and does not have any use at all. Though i would have loved the body of the S6 Edge on the Note Edge as well.
I have no clue why anybody is thinking i wanted the s6 edge, i never said the s6 edge just the standard gs6
No. The S6E is meant to look cute, that's it. If you want functional awesomeness its the Note Edge you'll be looking for.The s6 doesn't actually have separate panels for the edges does it?
??????from the too sliq side with the n.Edge✒??????
Nothing is misinterpreted. I was just generally saying that if one has the Note Edge (which is the phone to have, if you can have it) why would anyone even know what the S6E is? It like being able to have a Bugatti but talking about Mustang. Okay, that wasn't nice. I'm not accusing the S6e of being a Mustang but the Note Edge is so dramatically more, IMO, it make the S6e kinda look like toy.I'm sorry but I do not want nor do I ever will want an S6Edge. Topic was asking between a NoteE or S6E. So I mentioned that I am not a fan but would like the sleek design of the S6E on my NoteE. I do not know how someone can misinterpret my post when it is directly answering the post query. ;-/
Neither of the S6's do much for me, except they seem faster and smoother. If i did get one i wouldn't get the edge. I do like my Note edge screen but it isn't as smooth as my iPhone 6 even with Nova.
