How to enable LED light around camera cutout and more!
Is there a setting that I missed to reduce the brightness of the AOD info?
Thanks.
Mav. :cool:
Wouldn't work for me. I left it at defaults, switched the setting to do the notch only. When the app was open, it worked and looked cool. But I turned the phone off, got a notification and it lit up the whole corner of my phone and not the cutout. Rebooted, checked all the settings... with the app open, it looks like it works. Turned screen off, got a notification, did the same thing. Uninstalled.
FYI, S10+ 128 SD855 on Sprint.
I can't get it to work its driving me crazy
It does have alot of settings and is not very intuitive.
Follow the video above and it will all be OK.
Note: I found the setting that I was looking for. :)
Mav. :cool:
I installed the app on my S10+ and set it up just the way the video showed, but it doesn't work at all for email. That's what I really needed it for.
Is it supposed to work for email?
Which email client are you using?
I can't get the notification to repeat despite following the video. Any thoughts?.
Try this.
Mav. :cool:
pamatika
