I haven't had any issues caused by updates on the S10+, Note10+ or S20 Ultra. All snapdragons.it is an issue with the latest update (april security), which seems only to affect the exynos version of the Ultra. Samsung hasnt been doing too good with updates recently, causing more problems than resolving them.
I was referring to the updates in generalbut Mike, you said, you hav the SD versions, this green screen issues as i said was hitting exynos versions.
none the less, the S20 Ultra has gone from focus issues, which some would tell you took 2 updates to get fixed, to now this green screen issue when your Ultra overheats or battery is low, among other factors, is the Ultra so much of a different build to the S20+ that makes it susceptible to these things.
Yeah definitelyHi guys, just found out there's a new software update. Security patch for 1 April 2020. Should I download it to see if can solved the problem?
I'm glad to hear thatHi guys, I'm back with the latest software update Security Patch of 1 April 2020. After the update finished, I change the display setting to 120hz, and test out some apps and games, the screen is awesome, the green/yellow tint is all gone. Feels good can use the 120hz screen again.
