I do not know my volume limit pin on my Samsung S22 How can i find out what the pin is?
  • Start date Start date
A
Android Central Question
I need to know what my pin is is there a way to find out
Welcome to Android Central! You don't remember the PIN you presumably set? Or is this someone else's phone?
They didn't necessarily set one... I had this happen on my S10e. I definitely didn't set a PIN on the volume limit, but one did randomly appear once.
Don't know if it's a bug that hasn't been fixed or what.
That's always disturbing. I wonder if there's some default PIN that the user is supposed to know about.
That was my thought at the time. I tried the basics (0000, 11111, 1234 etc) and even lowered myself to looking through the tips and user manual. In the end I just reset settings.
elementssupply01
