Great battery improvement
miketko
231
Something else I've noticed is that you can use this "Disable" feature to get rid of the Cell Carrier bloatware as well! You may need to Uninstall Updates first...
How exactly do you get rid of the. Bloatware? Which ones are you disabling?
Sent from my SGH-I747M using Android Central Forums
dfb8085
215
I recently disabled s- voice on this thing, and my battery life has improved drastically. I never even really used s- voice, but I guess the services in the background still caused an intense drain. I just know that my battery life has gone up by a huge amount with that disabled. Has anyone else seen this?
Sent from my Samsung Galaxy S3, please excuse my brevity.
I noticed the same thing. Man that S-Voice is a battery hog. I would bet that my battery usage doubled
funkylogik
9,637
111
great tip m8 cheers. il try it. bein Scottish, ive never even tried svoice lol it would NEVER understand me :)
Reactions: robrecht
miketko
231
I'm not sure anyone has explained how to disable the bloatware?
miketko
231
same way but you need to uninstall any updates that you have done first for the bloatware. Then you can disable them.
Hmm. I'm brand new to the Android scene so I'm not even sure which are bloatware or even how to Uninstall any updates. I'll do my research. Thanks
miketko
231
Ok figure out how to stop the updates. Now I just have to figure how which are bloatware. I'm hesitant to disable something that shouldn't be
PookiePrancer
1,110
49
48
Any app that you don't think you'll ever use is bloatware. For me, even the Voice Mail app is bloat.
Forgetful
Energy hoarder
Jan 30, 2011
1,445
229
Basically anything Verizon and apps that come pre installed that you don't want. Like Color, Kindle...
Sent from my SCH-I535 using Tapatalk 2
miketko
231
Here are some apps that I want to disable but worried it may hurt proformance. Take a look. The ones with the Android icon.
funkylogik
9,637
111
dont disable any android/google apps. i remember i uninstalled one by mistake on a rooted phone + it stopped the playstore etc from workin. u cant really do much harm by just disabling apps but basicly only disable ones that u can see in ur app drawer but dont use (bloatware) :)
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Thanks for this tip guys. It helps battery for sure.
I also disabled a few more while I was at it.. Like sprint connection optimizer and all share since I won't use em :)
miketko
231
Ok thanks for the heads up
RandyRoyalty
