Seeing what everyone else is doing with their Galaxy S3
jodymcl
16
So, I love this damn phone. So glad I got rid of the iphone. I have customized it, play iheart radio on my road trips and have various widgets that fulfill my endless need of useless information (twitter, facebook, etc.) Other than the picture frame widget of my girlfriend's butt. What other cool stuff have you guys found?
SenseMonkey
1,773
15
I know you asked for some other stuff,but this is how i customized my beloved s3. :) My exterior is a white s3,white/gray case,zagg hd shield. Looks amazing in all white. :)
Sent from my S3:)
Apr 10, 2012
2,879
11
Keeping my most important stuff on my homescreens and am emilinating the need to press the power button by having 2 lock screen shortcuts as well as a double tap gesture to put my phone to sleep
As well as easy access to my lux brightness and battery information at the ready
Not that I can show you any screen shots of anything thanks to the new Android Central Forums dimensions glitch
On my Samsung galaxy s3 running android 4.0
Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreens
Apr 10, 2012
2,879
11
Well I can show you my homescreen but my notification menu isn't able to upload
funkylogik
9,637
111
check out Soundtracks homescreen thread in "stickies" for a MULTITUDE of ideas mate ;)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess ;)
funkylogik
9,637
111
http://db.tt/yWlp07eV
my main homescreen right now btw, live fish wallpaper over a pretty background. it may not seem functional but each of those dock icons has a secondary use by swiping up on one (for example, swiping up on the camera icon takes me to gallery... sms icon takes me to gmail..) plus the dock is scrollable so i have another 5 icons with their own secondary function ;)
funkylogik
9,637
111
oops sorry its Prozac's homescreen thread in stickies, soz Pro mate :confused:
goin_nil
1,054
13
.. play iheart radio on my road trips and have various widgets that fulfill my endless need of useless information (twitter, facebook, etc.) ...
I use the OverDrive Media Console to download free audio books from my library (library card number required) and listen to them on my way to/from work.
If you are into podcasts, pick up the Pocket Casts app from Shiftyjelly.
funkylogik
9,637
111
check out the "Screen Off RT" widget for a bunch of gesures like turning phone upside down, shaking, turning face down (my favourite) to turn screen off.
its free, ive had it around a week, and theres no sneaky leadbolt ad's.
just remember that although its an app, its in the widget list for some reason ;)
Apr 10, 2012
2,879
11
Thanks sooo much, I love it already
Wish you could have more than one gesture at once tho, but I'm loving this feature already
I wonder if there are any other apps like it so I may use a second gesture as well
funkylogik
9,637
111
no probs. i used to use an app called "shake it off" or something but it only worked with shake and was riddled with ad-ware.
id love one that would switch off when i close my flip case :)
funkylogik
9,637
111
....this is why im gona study coding :)
Apr 10, 2012
2,879
11
I found the other one to this app, its called screen off tl and it's not a widget so u can run both at the same time
So u can now use two gesures now so I set facedown and bottom up
No homo, lmao
Apr 10, 2012
2,879
11
All I need is now is a way to turn on the screen by using a gesture then I will be really happy
Apr 10, 2012
2,879
11
Damn, the app uses a decent amount of battery, i took my phone off the charger and already lost nearly 7 percent in 22 minutes uploadfromtaptalk1348284769892.jpg
funkylogik
9,637
111
they both use a lot :( i thought RT would only be usin maybe 2% which id live with. isnt this coz youve been testing them a lot? il check my batt usage for RT mate..
funkylogik
9,637
111
i have my phone on charge right now so dont know how accurate this will be.. once its charged, i wont use flip phone to turn off and see what percentage it uses.
id guess even using the power button uses some % hidden in android system or something.
i dont mind RT usin battery just when i flip the phone to turn it off but if its using a high percentage in background while waiting for a gesture/motion then ill uninstall :)
funkylogik
9,637
111
p.s, i notice Avast is pretty light on your battery... it was using like 8% on me so i uninstalled
Apr 10, 2012
2,879
11
Yea, it was probably cause I tested it alot, it's gone down a tiny bit since
Apr 10, 2012
2,879
11
Yea, avast only really activates when I download an app, otherwise it doesn't hurt my battery
