Hi all. I am new to this AndroidCentral but not to forums. I know how valuable they can be, so I am coming to you all.
My phone is jacked. I have an I747 AT&T S3. I had it rooted but not running a custom ROM. A couple days ago I dropped it a foot and it cracked the screen a little in the lower right hand portion of the glass. But the phone worked fine since then. The screen is fine, everything was fine.
Until tonight. I took the battery out to put in my Hyperion 4200mAh battery and as soon as I put it in, all hell had broken loose. First, TouchWiz would "stop" and leave my home screen blank. As soon as I saw that, I took it straight to the AT&T store. They do a factory hard reset on it, which I could have done for myself, and that makes it so that the keyboard throws an error and messaging throws an error. It says "Unfortunately, Samsung keyboard/messaging/Touchwiz has stopped".
Since my phone has the crack on the screen, it voids the warranty. Is there any way I can reinstall the Android software or anything? Like a "super" reset? Anything? Thanks in advance.
