A
AC Question
There was a problem communicating with Google servers, try again later - Galaxy S3
This is a nasty one. Started getting the message about problems communicating with Google Servers last week. Plenty of hits search for this, and none of the workarounds are helping me out.
1. Removed the Google Account and tried to re-add
2. Cleared all Google app caches and forced stop.
3. Ensured the Date/Time is set correctly
4. Tried with various accounts .... same thing
5. 2 Step not enabled
6. Non-rooted device. Hosts file looks clean (only localhost entry)
7. Not going to reset to factory since I have seen others state the problem persists even after the reset.
8. The network connectivity is fine, browsing to Gmail, Account, Play Store works fine.
I am at a complete loss as to why this is happening. Does anyone have any other things to try?
Thx
Thx
