Rajiv Jha
THANKS A LOT DEKCREATE ....i was so distressed that i cant explain ...i just didnt want to reset my phone hopefully i read your suggestion...thanks a lot dear
this is how to fix the problem... Follow instructions above.. This is how i fix my note.. You have to keep doing this each time you connect to wifi...here's how i resolved the problem with connecting to the internet on my samsung galaxy android
i went to settings - clicked on wi-fi - chose the network i wanted to connect to - pressed it down for 2 seconds and a window pops up - i chose modify network - and scrolled down to "show advanced options" - i clicked on it and under proxy settings i clicked on none - i clicked save
i'm not having any issues connecting now.
Hope that helps
Here's how I resolved the problem with connecting to the internet on my Samsung Galaxy Android
I went to settings - clicked on Wi-Fi - chose the network I wanted to connect to - pressed it down for 2 seconds and a window pops up - I chose Modify Network - and scrolled down to "show advanced options" - I clicked on it and under Proxy Settings I clicked on None - I clicked Save
I'm not having any issues connecting now.
Hope that helps
Hope that helps
Hope that helps
Hope that helps
