STARGATE
Ambassador
Simple. Next time buy Samsung galaxy S4 Active.
Sent from my GSIII
Lol. :thumbup:
But many of those had problems. Didn't they?
Sent From a Galaxy S4 Away!
Sent from my GSIII
erm, guys i got some problem my s4 also drop in to the water now the screen become dark but siri can work rice is what??
what meaning rice ?? put in the rice ??
hello guys im from Philippines. i also accidentally dropped my Samsung galaxy s4 gt i9505 in water for about 4-6 sec and i dont know what to do i rush to open it after drying it with towel to check if its still working the result is it still work but i noticed some lag from the toolbar and so on. but the thing that most caught my attention is the green led is always there even when i turn the device off. i also reset my device thingking it would go back to normal but it doesn't. my question is can it be possibly go back to normal?
Welcome to the forums! :thumbup:Hey guys!
I am new to this and I am in need of help. I dropped my galaxy s4 and now my screen is statically. I have a crack on the top corner but the led light still works. Can someone tell me what is wrong and what I need to replace.
thank you for reply from my post i tried the raw rice for 2 days and it work, but now after 2 weeks the green led is always there. how can i solve it? thank you in advanced but the device is still working my only problem is that green led even when the device is turned off it is still there.
so this is a common issue on s4 (kidding)
it occured for me yesterday in this way : " I dropped my s4 yesterday in water for 3 sec, after dropping I switched off and tried to clean it with a cotton and dry towel. tried to switch on and as I made myself sure it works , I turned it off & removed the battery , since I needed to go somewhere I did not put in rice at the time . at home , I dried it with a cool air flow of a hair drier ( I insist the air flow was cool not hot) and then tried to switch it on , everything worked fine . the only problem was that it does not understands the usb cable , it does not charge with it , so I put it in the rise . and it it in the rise for 24hours now "
does anybody knows what is going on with it ?
