Connecting to Microsoft Wireless Display Adapter not working
I have a Samsung Galaxy S5 (running Android 4.4.4) trying to connect to the Microsoft Wireless Display Adapter. When Screen Mirroring is attempted, both devices indicate that the connection is being attempted but after 20-30 seconds, the S5 indicates that the connection has failed. I know that the Microsoft product works since it can connect to my Surface Pro 3 and Lenovo Yoga 2 Pro. The Microsoft Display Adapter documentation claims it can work with Android products.
I wrote this because I saw one post that cklaimed that the s5 does work with the Microsoft adapter.
I have since chatted with a Samsung rep and below is the chat text. Basically they are saying that I need to use a Samsung adapter.
Visitor: have a Samsung Galaxy S5 (running Android 4.4.4) trying to connect to the Microsoft Wireless Display Adapter. When Screen Mirroring is attempted, both devices indicate that the connection is being attempted but after 20-30 seconds, the S5 indicates that the connection has failed. I know that the Microsoft product works since it can connect to my Surface Pro 3 and Lenovo Yoga 2 Pro. The Microsoft Display Adapter documentation claims it can work with Android products.
Nycer: I understand that you are trying to connect your device to your TV and you are unable to connect with the adapter you have .Is that right ?
Visitor: correct.
Nycer: May I know the model number of your phone ? You can find the model number beneath the phone's battery which generally starts with SM, SGH, SCH or SPH .
Visitor: SM-G900V
Nycer: Thanks for the model number .
Nycer: Please let me check.
Nycer: Thanks for your time.
Nycer: You need to connect with the MHL adapter.
Visitor: you are saying that I need yet another Samsung product because my phone is not following industry standards? I was told that my adapter and phone are both Miracast certified products.
Nycer: Not to rush you, are we still connected on the chat?
Nycer: I understand that both are Miracast certified products but screen mirroring can be done only with the MHL adapter which is a samsung product
Visitor: This does not make sense.
Visitor: correct.
Visitor: SM-G900V
