Have u found a tempered glass screen protector that actually curves around the edges
Think it'd be pretty hard to find one that curved around this. Just use it without a protector — really, it'll be OK.
how's the ram management? does it reload apps like S6/S6 edge? thanks
My GS6 and GS6 edge never really had any issues with reloading apps... and the same goes for this phone.
Has it got any multi window software if so how does it compare with multi window on the note 4 / 5?
Yup same multi-window and pop-up window features.
I saw the standard s6 edge, it's display looked as crisp as if it's on a real paper. Is the display as good (or natural) as its on the standard s6 edge/s6?
Great display still. Crisp, bright and accurate.
For both this phone and the note 5 I'm mostly interested in battery life. I know you have not had it long enough to make a comment but when you're ready I would love to hear your thoughts. Especially comparing to the standard s6 or the note 4
I just posted this over in the Note 5 forums:
"Weekend is over! I can give some kind of battery life impressions. In short, I'm not upset with the battery life.
I've been ending each day with about 15-20% battery left, that's after roughly 15-16 hours off the charger, and with 2.5-3.5 hours of "screen on" time. That's with ~90% screen brightness (+ auto brightness), and all of my accounts syncing. Nothing hard-hitting really, just usual email, social networks, browsing, reading, camera, podcasts and music, maybe with some occasional youtube videos or streaming.
That's not bad at all, and nowhere near bad enough for me to be upset with it. FWIW I also get through a day on the Galaxy S6, but not as comfortably."
The menu of the camera setting for my Galaxy S6 Edge won't stay on.
I press the camera icon and the screen appears with the toolbar at the top of the screen. I press the settings gearwheel icon and the Camera Settings menu appears for the briefest instant before the screen reverts back to the previous screen. I can't get the menu to stay on.
What can be done?
seems like a bug. clear data in the camera app, restart the phone. if it persists, return the phone for a new one.
What bloat ware can be Uninstalled for AT&T version?
Only have an international version, sorry. Chances are you'll be able to disable most of it, uninstall very little of it.
True, is it possible to extract this camera app for us?
Thank you!
Nope.
may be a dumb question, but where is the speaker for this phone? Is it the same as the S6 (back of the phone)?
Speaker is on the bottom next to the USB port, just like the GS6. It's passable for notifications, ringtones and speakerphone calls, but isn't all that great for listening to music or podcasts. Definitely go with an external speaker or headphones.
Is the phone slippery? How does it feel in the hand (compared to HTC One M8, is it more or less slippery?)
It's pretty slippery, mostly because there just isn't much metal on the sides of the phone and the curve isn't really helping your hand wrap around it at all. I still don't feel comfortable holding it without a case, just like the regular GS6 edge.
The M8 is pretty slippery as well, but for different reasons — that phone just doesn't have anything to hold onto, and the materials are soooo slick. The M8 is at least small enough that you can wrap your hand around it.
Is it more responsive given the extra gig of memory?
With the latest software updates the GS6 & GS6 edge are pretty responsive even with 3GB of RAM. The extra 1GB isn't going to do much to change that in either direction — that's all about just holding extra apps and processes in memory.
