Wondering is you all are using a third party app like Textra or the stock Samsung sms app? I am using textra but wondering if the stock app would be just as good and then one could use the edge better for its purpose.
I use Verizons messaging app, Message+. I like it. Best part is you can send regular sms over wifi, I don't always get great service at my house/work so it's a huge plus for me.
That you can accomplish with several apps. I happen to like mightytext. It does not tie you to any give messaging app either.You can also log in on your pc and send and receive texts with Verizon msg plus. Nice Verizon feature.
....... since Textra doesn't alert on the Edge screen, from what I read.
Google Hangouts and Google Voice allows SMS over wifi. I've used on several airplanes.
No to their phones and they aren't using it.Only to other people that use it though correct?
Textra is running fine on mine. No lag noted so far, I'll keep an eye on it though.Do not install this Textra junk, it causes huge lag on my Galaxy S6 edge+ that I had a very hard time troubleshooting until I restored my phone to factory settings and noticed the moment I install Textra, this lag comes up. The lag I am talking about is the random unresponsiveness of the phone when it's in standby mode and you are trying to unlock it, swiping the screen would do nothing. Uninstalled Textra and the issue never came back!
I ran Textra on my Note 4 and on this device with zero lag. That sucks that your experiencing that because I couldn't imagine not using Textra
I love Textra man, the ability to be able to blacklist spam SMS is amazing. Wish I could use it again.
You don't see any lag right away, just give it sometime and if you ever see that when your phone is locked and you're trying to unlock it but swiping the screen does nothing for a few seconds then all those swipes start to register all at once, that's the Textra issue I'm talking about. The moment I uninstall it again, that never happens. OS is Lollipop 5.1.1 on S6 edge+
Tried many factory resets / clearing the cache partition, no luck, it is Textra.
