Hi there - This morning I got a message for a "Urgent Update". Looks like it updated the Edge screen...? Anyone else get this?
The update is for the ability to change where edge icon is on your screscreen. You can move it up or down and on the left or right side of the phone now
If you swipe left on edge screen it gives you apps as well as contacts. That's what it's added to mine
Should be in your edge screen settings.Do you know how I can get back the update.
I removed an app from the Edge and put it back to get rid of the instructionsWith the update I am now always seeing the "how to instructions"..shouldn't these be able to be dismissed?
