DESPERATE: Bluetooth connection drops
JOHN BEST3
5
S6 + Edge Att.
OK so here's the deal:
  • There are two bluetooth connections to the car; Calls & Media
  • If I have both connected, the bluetooth connection constantly drops.
  • If I disconnect Calls and leave Media connected, its flawless.
  • If I disconnect Media and leave calls connected, flawless.
  • But when both are connected it wont last 5 minutes without disconnecting.
This issue is close to making me want to drive the car into a tree - if anyone has a suggest I seriously appreciate it!
JOHN BEST3
5
Thanks - its the BT connection to a 2015 Acura. I have reset it several times. Another clue is that if the phone is reset to stock it works well for about 2 weeks. I have very few apps any I restore them the day the phone is wiped so its not an app or setting...it's almost as if something get cached and then starts to falter....
joshmil
5
I have the same issue with my S6+ and a Nexus 6. I have a Honda Civic and it started after the updates to 5.1 I have noticed that I'd wifi is off it happens a lot less. It's frustrating hoping that 6.0 fixes it.
