Hi everyone
I did the latest update to 6.0.1 last week on my Samsung S6 edge plus and since then my S note gives me the message
'Unfortunately S note has stopped'
I've reset the phone, uninstalled S note viewer and installed it again and searched a few forums but can't find anything to fix it. I did try one other thing which was to update my language from the 'Language and input' setting but that didn't work. I usually open S note after logging into 'My KNOX' so not sure if it's that ? When I go to the S note viewer app it also tells me I have no 'SPD files' even though I have 5 of the blighters and I can see the folders !!
As this isn't working I now can't get access to my passwords and personal data. Does anyone know if I can access this data any other way, maybe via another app ? Tried Evernote but couldn't work it out.
Thanks in advance
Joe
Thanks in advance
Joe
