While I went to different samsung shops to take a look at the samsung galaxy s6 edge golds, i realised a difference in reflectivity, possibly material. although it is the same phone, some of the golden s6 edges are more reflective like a mirror while others look brushed and are not reflective, like a solid color like the white s6 edge. Both are s6 edge golds. But there is probably a difference in material? Since that there are two different types of s6 edge gold, would you get the reflective one or the non reflective one? Cant post links so cant get you example images..if you google s6 edge gold you should be able to see difference in reflectivity. Not referring to those images taken from commercials as they are taken in controlled environments. Referring to those taken by users at exhibitions or homes.
