Anyone know why I keep getting this message when I check to see my battery stats? I tried resetting and charging to 100% again but no luck. It keeps showing this. I'm using a wireless charger. I doubt this could be the issue?
Do you mean when you go to settings/battery you get this message ?
I've just tried my one whilst on the wireless charger and is shows the full info page no problem so it seems weird
Have got a 3rd party battery app loaded ?
The only time I've received that is when I checked while it was plugged in and charging.
Just tried it on cable direct, no problem
What happens when you click on battery usage then refresh ?
I'm at 100% but still get graph but says no data available in listing, obviously
It refreshes the time since I stopped charging but the not available message remains.
very strange you said you did a full reset are you running 5.02 ?
It actually corrected itself yesterday without me doing anything. Yes I'm on 5.02.
Good lets hope it stays that way
Battery usage data not available showing and when I didn't plugged it getting shutdown
