Looking at buying this case or the official Samsung Clear. I have read loads of reviews and watched lots of videos. The one thing sticks out for me is a review that says the spigen has ruined their screen. That the band that goes around it is too tight and has caused the pixels on the display to mess up. (Amazon uk review) Has anyone else experienced this? Thanks.
No issues with the tightness of the Spigen case with pixels. That would be more of an issue with an LCD screen vs the AMOLED.
The Samsung clear has this weird protective film under the packaging layer. If you remove it a nasty residue will remain but can be removed with goo gone. I attached a picture with the packaging film separated from the protective film. It was weird seeing two layers on top of the actual case. After reading/watching the reviews it wasn't just me.
Bumper: The Samsung case doesnt protect the top and bottom, its more slippery, and although it is easier for headphone and charger access. The Spigen has a full bumper coverage which doesnt add much bulk, but it is an issue if you use a charging cord or headphone jack that is thick near the plug.
Back: Spigen offers some grip until it gets greasy vs Samsung with the extra film is a little better, however the you can get caught on the edges of it, and I can see it peeling over time and looing bad. Fingerprinting is a little worse on the spigen.
Color: The Spigen Gunmetal looks great with the silver. The Samsung case to match the black phone is this blue metallic which does not look good with a silver phone.
The back of the neo hybrid crystal has a tacky feel. Enough so that I can rest it on 3 fingers and tilt to over 70 degrees without it slipping. I have 5 cases and it is the one I use daily. I did switch to a heavier case for a recent trip to Disney but now that I am back the neo hybrid crystal is back on.
I think both of the clear cases are kinda slippery... The spigen at little more so... Probably why I grab the regular neo hybrid more often... I find myself either using the textured neo hybrid or nothing I guess... Wish I could be more help... The skin will help give it some grip I'm sure but I like being able to take the protection of when I want...
Sent from my Adamantium™ S7 edge
I have never had any of those issues with Spigen cases. I've used Spigen on my Note 4, S6 edge, and S7 edge. I currently have the neo hybrid clear in satin silver on my s7 edge. Only thing I would give a negative view on, is that it's very slippery in the hand. None of those issues you that mentioned though.
Sent from Sir Cletus Sexy IV.
(S7 Edge Titanium)
