Whitestone Dome and Spigen Neo Hybrid Crystal case
Samsmome
270
Can anyone chime in if the Whitestone Dome screen protector works with Spigen Neo Hybrid Crystal case? Also is it curved for the Note 8?Thanks for any and all help.
Its compatible on the S9... I ended up exchanging the Neo Hybrid for the Ultra Hybrid and they both work with Whitestone. It's a tight fit though so you have to be careful when putting on the case.
Yes, it is curved for the Note 8...
These dimensions come in handy...
Flykxd133
