Originally Posted by
mustang7757 No worries I see your reply
Possible but going to boot logo that's usually means soft bricked phone , can you get into the recovery menu?
It was going to logo screen before - upon crash(?). Now the phone screen lights on after I plug it in - and shows Battery charging icon - that's all. No progress and no response. Can't get to Recovery menu. If I try - the screen will get blank (like it did with logo screen stuck).
Before drain, I had to use reset again to get the screen bring back. The reset was not responsive every time, but from time to time I could get it back to logo screen from blank.
