Wi-Fi issues
kyleresq
196
6
18
I had this same issue with my S5 but I don't recall what fixed it. The Wi-Fi icon at the top of my screen is constantly switching between Wi-Fi and 4G. I have had my phone for 3 weeks and I swear this just started. ATT pushed an update a few days ago. Smart switch is off. The option to auto connect to ATT hotspots is off. It's happening at home (att) and at work (Comcast). Ideas?
welshmikie
Active member
Jul 29, 2014
40
I have the same issue WiFi at home fine. But at work use a Huawei mobile broadband device my s7 edge will connect but in seconds will disconnect and won't reconnect
MartinMPL
378
I think there is an issue. Verizon users reported a working fix, my OEM device still does this. Usually I see a monetary disconnect and the toast pops up to say connected. Sometimes it seems to give up and stay on mobile data and I have to switch WiFi off and on again.
amotter
391
51
Kyle, same problem as above, what is not enabled?
Using Verizon.....does anyone know how to fix this issue?
