How do I disable the my places on the Samsung Galaxy S7 Edge?
A
AC Question
Everytime I go to work and then back home or vice versa, it disables my touch key duration and changes it to always off and LED indicator along with other settings. This has become very annoying as I have to always keep going back in and change the settings back to the way I want them.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Welcome to Android Central! Are you using any kind of 3rd party location profile app like Llama?
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
Are you using the My Places edge screen? If you want to get rid of that, just swipe in show an edge screen shows, tap the gear icon at the bottom left of the screen, and uncheck the box about the My Places column.
ecstasy89
