And this is the point I don't get about you. You've admitted several times, most people can't see this problem, but it's there. If we're talking about an issue regarding how a screen looks, and if most people can't see it, then why doesn't matter? What on Earth could possibly be the problem if the Invisible Man wears tacky-looking clothes?
Because I don't like manufacturers putting in an End of Life date for products we buy. Apple does this through business upgrades but their products usually can you last you up to 5 years.
The more you use your AMOLED display, the worse it gets, which means an S7 Edge may look significantly yellower, duller, with "burned in" images in years 2 or 3 of ownership, and they if no one educates consumers on these drawbacks, consumers lose out.
I own so many Samsung products and i go through them quickly, but I am definitely NOT someone who is going to champion AMOLED with its significant lifespan limit, and if continue to be wary, then manufacturers might actually work on this issue more extensively. I'd expect an AMOLED to display to last 5 years minimum with no color changes or "burn in". IPS can so that's what I prefer now.
I actually think one of the major reasons why Laptops, Computers etc are NOT AMOLED (they are more expensive its true) because of this exact reason. Manufacturers look at the AMOLED spec sheet and they realize computer screens are left on exactly like a demo phone would be at a store in normal usage, and that would be disastrous for the computer. We'd be going back to using "Screensavers" again.
