Other question, about the sound. I have read that many complain about the volume which is too low. Impressions?
I will check that out, thanks. I never run into a compatible headset when I was both on S3 or Xperia. All the big names weren't working with their volume control.
I went back with Apple for two reasons: privacy and music. Privacy, because I think Apple is tighter with user data compared to Google, and music because, well, I think an iPhone works just better for music.
Quality of songs in any android phone cannot match iTunes converted music files in your iPhone mp3 is much lesser quality of sound than converted mp3 through iTunes which I think AAC.
Android can play FLACC. This is lossless, and is in fact one of the best, if not the best formats for audio quality. Even the best quality mp3 is inferior to that.Quality of songs in any android phone cannot match iTunes converted music files in your iPhone mp3 is much lesser quality of sound than converted mp3 through iTunes which I think AAC.
My Samsung headset also uses that same configuration as the iphone jack. So I guess they should be interchangeable now? //uploads.tapatalk-cdn.com/20160524/554099a333702a2f3fb51f57166fee56.jpg
I have several pairs of good headphones and earbuds. The volume level in the S7e struggles to drive some hp. Way lower than some of the older Samsung.I haven't used my headphones with my S7 Edge yet, but have used speakers with it and I don't recall noticing a difference in volume level from my S3.
Your best bet is to get a high-quality pair of headphones. My Polk Audio noise-cancelling on-the-ear headphones are amazing - you hear things in the music you have never heard in it before - and I don't really need to use the music app's equalizer to enhance it (but on my tiny bathroom speakers and house's in-ceiling speakers I do). BTW, I did notice that the S7 Edge has a more quality, clearer sound from my tiny bathroom speakers than my S3 had at the same volume.
Am I the only one that can download music from iTunes and have it automatically appear in my Google Music miraculously with no 3rd party app?
No, but there are many of us that prefer all our music to be on the SD card and not just the cloud.
AFAIK Google music saves to phone memory, not SD card.Say what? I can save my google play music to my phone.
