Depends on how you want your phone, some of these really aren't advisable. Likw turning off device manager. We've had reports of the phone suddenly having password issues after updates, and device manager works as a way to get into the phone. And you want to turn it off?I get about 1% drop in every 3 hours or so on WIFI and every 5 hours or so if everything is off. But when LTE is ON without wifi, 1% is consumed for every 45-1.5 hours (it depends on signal strength). From your chart it seems your phone is held awake for 30 mins something is producing a lot of wake locks. Check from the wakelock detector. The following are settings that i have.
1) Turn off NFC if that's on.
2) Remove Android Device manager if that's installed, it caused a lot of CPU wake locks using Maps.
3) Try setting GPS positioning to use only GPS instead of GPS+WIFI & Mobile Networks.
4) Turn off google now cards and location history.
5) Set app power saving to always for apps those you don't use often or those you don't need notifications from.
6) Turn off background data for apps you feel don't need background data. This option is only for mobile data.
That's ok, using Find My Mobile, but not everyone seems to know about it. At least ADM is active by default. FMM still needs you to opt in.Well I felt I could use the samsung's built in Find my phone option for that. I wasn't aware of the password issue.
OP; Turn off things you don't need, start with the Gsam battery monitor, Bluetooth and Wi-Fi if your not using them and any other apps that don't need to be running while your phones asleep.
1% per hour isn't that bad while resting.
It does. Any app installed and running in the background takes up battery. Although I'm not sure how much GSAM takes.Gsam takes up battery?
