Is 4 hours of screen time good for my galaxy s7 edge 935fd?
Hello,
I just bought a galaxy s7 edge 935fd and i want to know if it is good to have 4 hours of screen time. I do some web browsing, play clash of clans and clash royale, chat on whatsapp and fb messenger. I have location settings on, sync on, aod on, brightness between 25 and 50% My tmobile signal is on average 1 to 2 bars.
Re: Is 4 hours of screen time good for my galaxy s7 edge 935fd?
Welcome to the forums. Take a look at your battery stats and see what's using most of your battery juice. Usually such a bad reception will make your phone use a lot of resources, specially when using mobile data.
4 hours is good for me on the latest firmware. Got much more than that originally
Depends on total uptime. I only use up 4 hrs of screen time usually a day, but the standby time is above 16hrs. So that's pretty ok on my usage (My old Note 2 gets only 10 hrs standby on 4hrs screen on, and it's all me since when my mom started using the Note 2 after I got my S7E, it lasted over 2 days for her on one charge, lol). If you're getting 4hrs screen time on less than 12hrs standby, you'll have to check on battery suckers.
