On the Samsung Galaxy S7 Edge, is there a way to keep the keyboard on symbols. I used to be able to put multiple exclamation marks in a row, but not it automatically goes back to regular keyboard after pressing one symbol. Very frustrating!
It's been a while since I've used a Galaxy device, and don't know if it's possible. However, you can check through the keyboard settings to see if a setting allows you to keep the symbols screen up longer. Alternatively, you can likely long press on another letter/number to quickly access symbols. If still nothing works then consider an alternative keyboard. Not the ideal solution, but something to consider in the interim.On the Samsung Galaxy S7 Edge, is there a way to keep the keyboard on symbols. I used to be able to put multiple exclamation marks in a row, but not it automatically goes back to regular keyboard after pressing one symbol. Very frustrating!
