Tachead7075
Active member
Thanks. So we are likely looking at a January public release date then? February if something goes wrong.
Someone posted this earlier....Thanks. So we are likely looking at a January public release date then? February if something goes wrong.
Factory reset shouldn't change your firmware version. You'll stay on the beta.Does anyone have any idea as to whether if I factory reset my S7e if I'll be back on "stock" firmware or be able to download the beta? My S7 has been pretty sluggish since before the beta and while the beta has helped tremendously i'd like to just get it running completely smooth again. I'd like to use it as my main device and give the iPhone a break for a bit.
Once installed, it asked me to enter my number to enable RCS in the stock messaging app too.
What network are you on? I've seen this mentioned elsewhere but I didn't get asked
https://youtu.be/1KwsCeLz08w
beta 5 video for you guys, battery for me is good have had some heat problems tonight but overall its snappy and stable
The battery seems great on this release.
Do we not get Google Assistant with this beta thing? I missed the sign up.
Even the Nexus phones didn't get that on their Nougat update. Pixel exclusive.
Theme store is now working
