If i record video on my s7edge how can i play it back on my hd tv?
Printable View
What brand and model # of your tv? Are you using a Roku or another streaming device by chance? There are a couple of ways, but these items can make a difference in the options available to you.
It is an RCA hd television. I think i might need to buy a dongle hdmi thing.
Hi Dave,
If it has no internet connection on tv you will need an HDMI dongle like Chromecast
I was looking at the actiontec screenbeam 2 mini. Sounds like it would work. $30 at bestbuy
Honestly don't know about this one but for the same price you have the Chromecast 2 which is great and made for Android from Google
Will chromcast work without wifi?
Yes but you will have to use your phone as a hotspot
So no hhhhhhhh
Well.....tis the season. Catch a Black Friday/Cyber Monday sale on an up to date TV with hdmi inputs and get a version 1 Chromecast. Those things are dirt cheap all over the place.
Why buy version 1. Does it work better?
You really won't notice that much a difference in quality of the video from your phone. I didn't notice a big difference when I went from the first version to the second one. YMMV
I have that (screenbeam 2 mini), works great, slight lag if watching phone/computer at same time as TV its about a 1/2 to 1/4 second behind the device that it streaming to the tv. other than that i like it.
Version 2 is dual band and improves on the very slight lag in the original Chromecast.
I didn't notice a lag with personal videos from the phone, but I did with streaming apps.
With version 2 can I enjoy Netflix or is mouth out of sync with sound?
You should be fine with version 2. As stated above, the processor is so much better and you shouldn't see a loss of sync at all.
You can try anycast from eBay about 15 dollars it works fine
I know you are looking at a cheep chrome cast but you shoud take a look at the mi box at Wal-Mart
https://goto.walmart.com/c/1943169/6...38%26veh%3Dsem
It is $69 but is a full blown android tv box with chromecast builtin and is fully licensed by google so it does have the play store and all other apps from google. I own this and i can say for the money i am very satisfied with it. It runs smooth.
Also as an added bonus you can install games on it and depending on the game most run realy good. All though it is no nvidia shield tv.
I'd stick with a name brand product. The Amazon Fire Stick will work, you do need wifi available the first time you pair the phone and the Amazon Fire Stick but after that you do not need an internet connection/wifi. The new one with the voice remote is $40 at bestbuy.
How can it work with no wifi and no internet? Is netflix one of the apps?
I have the Microsoft version. It connects well however Netflix is unwatchable due to poor video sound sync so I need a device with netflix on it.
Sorry for the late response. You do need internet the first use to pair the Amazon Fire Stick and your phone. After that you do not need accessible wifi. With the Fire Stick you go into settings>display & sound>enable screen mirroring. Then on your phone swipe down and select smart view (if you don't see smart view then tap the down arrow icon) and it should see your Fire Stick, select it and then your phone should mirror to the TV. You will then launch the NetFlix app on your phone. Here is a video (they go about locating the Smart view a different way) https://www.youtube.com/watch?v=DcGQFnEA0aE
