Got the S7 Edge during the promo
Lepa79
2,683
I got one from Bestbuy on VZ on the 24th. Carol blue. Great deal. I attempted to put Nova Prime on it but the resolution is a bit off. Not sure what is going on but something is not right with Nova on s7 edge. It just doesn't feel "polished". I'm not a newbie for Nova and I'm not sure why it is looking strange.
robinhelenehebert
1,164
What's off?
Lepa79
2,683
What's off?
1st image is touchwize and 2nd is Nova with Pixel icon set. Look at the widgets and Google search. They are just too pig. Feels like resolution is off on the clock widget and water widget. They look much better on touchwize. Even google search looks so big and just not polished like it looks on touchwize. And no, I can't get them any smaller.
chanchan05
Q&A Team
Nov 22, 2014
8,519
Change the grid size. You can change the stuff more on Nova. Here's an example on my S7 Edge:
App drawer accessible via a swipe upwards. Most used apps on the Edge panel.
Lepa79
2,683
My grid size set to 6x5. Doesn't matter how much high I go, widgets just still look bigger on Nova. This is only an issue with S7 edge. Been using Nova for years and never came across this.
jejb
380
I normally use Nova, and also got my S7E in the pre-BF Best Buy. But with the ability to use a 5x5 grid stock, I've found no reason to use Nova so far.
anon(9408097)
759
View attachment 246897View attachment 246898
Is that the stock google now search widget or a custom one? Mine doesn't look like that. Yours look nice and new and modern and beautiful. Mine looks like a simple white rectangle -.-
Oh and btw yes I put nova on all my Samsung phones. Makes it feel snappier. No nova on any other phone.
Lepa79
2,683
It's the one that came default on my s7 edge.
It will turn into a circle when you drag it over.
Lepa79
2,683
Nope. Still rectangle. What havent I updated? Oh maybe it's because I'm still running marshmallow?
I'm running marshmallow. But mine is the Carol blue so may be it is packaged differently since its the new build? The phone had the rounded one out if the box on TouchWiz.
jejb
380
For making the icons similar, go into Settings->Display and Wallpaper->Icon Backgrounds. Change to Icons with Backgrounds and touch Done.
If it's greyed out, you probably have installed a theme.
Not sure how his search widget looks like that. I also have the Coral Blue with all the updates available and it has the normal search bar.
EDIT: Looks like it's kind of luck of the draw who gets it:
https://verdictforu.com/2016/11/03/...roid-reportedly-getting-a-circular-face-lift/
anon(9408097)
759
Can't wait to get it on mine. Looks great!
textura
