Folks,
I'm hoping you can help my little problem here -- it looks like my phone absolutely, positively won't ring when I receive a call. The first time I noticed this, I was actually using my phone, going through some e-mail messages, when I received a notification that I had a new voicemail message -- I didn't get ANYTHING for the call itself. No ringtone, nothing on-screen, nothing.
I can't for the life of me figure out what's going on -- I've got my ringtone turned up as loud as it will go, it certainly works when I try it, and so on. No, I don't have any of the callers blocked, or anything like that. I certainly don't have any kind of "do not disturb" turned on -- I get notifications and sounds for everything else.
I reboot my phone at least a couple of times per day, and I have rebooted since any of the "calls without notifications" have happened. I'm not sure about whether the two calls that I've received since the first one showed anything on-screen or not -- I haven't been near the phone, but I certainly was within hearing distance if the ringtone had actually sounded.
If you can send any sage words of advice my way, I'd sure appreciate it!
Thanks!
Thanks!
