Does LCD need replacement if touchscreen and glass are only defective for Samsung S7 Edge?
A
AC Question
Hi, so my question is "Does LCD need replacement if touchscreen and glass are only defective for Samsung S7 Edge?" I have a phone that has the glass broken and the touchscreen works everywhere except a line in the middle. Does the entire module, ie glass, digitizer and lcd need to be replaced or can I just replace the digitizer and glass?
IAmSixNine
3,157
72
While i have not taken apart a s7 edge almost all phones made with in the last few years have had the Glass and LCD or AMOLED glued together.
So im pretty sure if you have a touch screen issue and/or broken glass the AMOLED screen will need to be replaced.
Im sure you know this but the samsung galaxy s7 s7 edge use AMOLED displays, not LCD.
AmeliaRodriguez
