Paul6726
I had the same issue!!! Drove me crazy, it was the S photo editor app that was the culprit I uninstalled it and no more pop down!!!
This started happening with my Note 8. It's driving me nuts! I've tried all of the above suggestions, and nothing seems to help. I even tried the premium edition of Malware Bytes, but this bigger keeps popping up (or should I say dropping down). I can't seem to find much info on the internet about it.
After working on this for several weeks I found at least a solution that seems to beat the heck out of deleting random possible apps.
I confirmed with Sprint that these "balloons on a string" can ONLY come from an App that is running, although it may only run for the length of time the app appears. So, without further adue...
Next time you see one of these balloons on a string:
- go to the Play store and click on My App & Games.
- Sort by Last Used.
- Look amoung the most recent apps run, as in the last few minutes. Your looking for an app that says it ran, but you know you haven't used it in the last few minutes. Ignor common apps that are probably running like chrome or mail or a loader that hasn't had issues before.
For me it turned out to be a Bar Code scanner I had downloaded a while ago and hadn't used in weeks, but there it was in the list "last used 2 minutes ago"... really??? Uninstalled and haven't seen a balloon since.
no it's not Samsung related I have a Droid Turbo 2 and it's been doing the same freaking thing drops down and now I'm getting this stupid hot air balloon that pops up on the side 2 with stupid advertisements I just tried the Google thing let's see how it goesI believe most of these comments are BS. I have this problem too, and none of the various apps or check boxes that are suggested to have caused the problem (Peel, calculators, etc, or opting out of Google). Also, there is no such app called "Avast Mobile Security" (at least when I go the app store). There is Avast antivirus 2018 - is that what you mean?
My Samsung S8 has this problem, but I also have a Pixel2 that does not have this problem. Is this a Samsung specific problem?
I will be escalating to Verizon of Avast Antivirus does not fix the problem.
As luck would have it I am unable to
find and sort recently added apps by date since my Application Manager is gone. It usually appears above my list of applications but it's not there anymore.
Help
