Title says it all. Phone info in attached pictures. Have had the phone for a couple years now. To the problem:
Phone started acting weird, so I did a factory reset, wiped media partition cache multiple times to be sure. Mounted \system and rebooted. Worked fine for a couple days, then WHILE USING THE PHONE, the screen when ultrabright. Swiped down, and Outdoor mode was on, and auto brightness is gone. I can literally find only 1 post on the web about this. Some sort of residual code from the S6 models. Everyone says to factory wipe but I don't want to be doing this every couple days.
Any ideas on how to fix this?
Thanks in advance.
*Should mention that since getting the phone, this is the first real problem I've experienced.
Thanks in advance.
