That's too bad. Considering I have 6hrs.Both didn't show, sorry
I've been losing about 40% battery life overnight while the phone is not used at all.
Facebook was my #1 battery drain at 43% so I uninstalled it today.
Now when I check my battery usage I see this "10201" icon.
Has anyone ever seen this before?
87% drain in nearly 6.5 hours is pretty high.
How many bars do you get on average? If you have 2 bars or lower, then that could explain the high battery drain.
Also, can you explain how your usage pattern is like? It really helps us understand how a phone should behave based on usage.
Hmmmm, OP. Maybe try some of these to see if it makes a difference.where I work and live my reception is excellent,I do maybe 3 to 4 hours of calls per day,stream music 2 hours or more,play dominoes a lot .But I work outdoors in Vegas of all places so the screen is on auto brightness which ramps it sky high
That is a very interesting observation!
I have noticed that the phone seems to lose more battery at night.
Probably because I have a better signal during the day while at work.
Right now at work I have 3 bars.
I recharged the phone this morning, it was 100% at 8am and now down to 89% with almost no use.
