how to turn off bluetooth notification sound?
retired guy
Hi. New guy here.
I have connected my S7 to my car for hands free calling, but it has an annoying problem of making a notification sound every time I drive past a spot where it recognizes a possible Bluetooth connection. At times it can chirp several times a minute!!
I'd like to disable the notification sound for Bluetooth only while still allowing the notification sound for texts or emails to be heard.
Can this be done?
Turn on Bluetooth... Find the device you connect your car with... Tap the gears icon to get into settings for that connection (!!!)... You should be able to find something like "new connections" or such....
Thanks for the reply.
When I click on the gear icon (handsfreelink) there is no option for "new connections" or anything similar. Options are rename", "unpair" and then on/off for "call audio", "media audio", and "message access"
Iknownothin
