madkoda12
Not to mention that you would probably get another hard pull on your credit report when applying through Samsung. Another option, if priced the same, is buying from Best Buy with your carrier. They usually run free financing for a certain number of months. Also since it's technically on a Visa/MasterCard Best Buy card you would probably qualify for Visa/MasterCard extended protection.
only thing is bestbuy doesn't sell t-mobile phones (only the pre-paid plastic bordered phones) Unless you'd wanna go unlocked.
