Wondering if anyone has some suggestions on wireless charging pads or accessories for the S8? Feel free to share your links, it'll help all of us find cool stuff for our S8's
(thanks in advance) ...
I ordered 2 of these and have been very happy with them.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU5924865
I have the Seneo "fast charge" chargers and used the S8 Samsung wall plugs. I also have two Seneo plugged into non-Samsung wall plugs (dual port 4.8A iClever) and through longer cables (one is six feet, the other ten) and they charge just fine.I ordered these:
- seneo charger stand - https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6183032
- anker quick charge wall plug - https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6183032
- anker usb cable to connect them - https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6183032
Hopefully this will provide the same quick charge as with the samsung wireless pads. I had the samsung wireless stand at work for my Note 7, which was returned when I had to return my Note 7. I found the lip on the samsung stand to be too small, so you had to carefully place the phone on the stand - pushing the back of the phone flat onto the stand - basically a two-handed procedure. Otherwise the phone would fall right off because it would slide of the small lip. This seneo stand seems to have a bigger lip on the bottom so will hopefully be a bit more forgiving of the placement.
