This is weird.....can't find the weather widget when using Nova launcher on S8+...any ideas please? Thanks.
You can also use the weather widget in the Google search bar. First you need to enable 'labs' (open Nova settings and long press the volume down key). Then switch 'allow weather in search bar' on in Nova settings - labs.
The weather widget is not available unless you use the default launcher, I tried using the Samsung UX just for that but the features on Nova are too good to not using them, so I just downloaded XWidget and Downloaded their online Galaxy S8 Weather Widget done by Jimking and it's basically the same, now I have the best of both worlds.
It's not just that widget. Entire Samsung apps just don't show when using Nova. Very odd.
Thanks I was trying touchwiz launcher just because the widget didn't work with nova but installed nova prime as soon as I read your post. However, is anyone having issue with widget info dissapearing randomly? for example sometimes all I see is the arrow to refresh and the degrees symbol but I dont see the actual number of the temperature, refrehsing does nothing and the only solutions is to delete the widget and create it again
