anon(1070578)
Tested two S8+ and the issue is the same.... It's a lot more noticeable when panning left and right with the blue sky and trees or other objects in front. Not sure what to do now.
Good luck! My prediction is that they will return it (or perhaps a scratched-up refurb substitute) and say it's fixed, and there will be no difference in its behavior. I hope I'm wrong, but they seem to be satisfied whenever a phone passes their standard tests. So if there's a widespread problem that their (woefully inadequate) tests fail to detect in the first place, they just automatically declare victory.Samsung is asking me to return the phone for repair, so I am going to let them try to fix it. I will definitely keep everyone here posted on what we find out.
You haven't said explicitly whether you tried abruptly panning from green trees to bright sky, which is the specific circumstance in which OP and several others of us in this thread have encountered the problem. If you have tried that, could you be so kind as to post your video so we can compare it to OP's?I was sitting outside when I first read this and tried to duplicate it. I don't have this problem.
Not even close. However, your evasiveness is indeed the answer I seek.What is the definition of duplicate? That's the answer you seek.
I agree. I hope OP sends sample videos to explain the issue. The average user is using factory settings (1080p) to video their kids or pets running around the house. They love their little darlings and don't notice anything wrong. Then there are those who simply don't notice the pixelation or don't pan the sky. Perhaps others have a phone working faster due to fewer apps running in the background and actually get a good video. Who knows. Bottom line is I don't believe Sammy will fix it. Either buy a G6 or keep returning phones until you get a good one.Good luck! My prediction is that they will return it (or perhaps a scratched-up refurb substitute) and say it's fixed, and there will be no difference in its behavior. I hope I'm wrong, but they seem to be satisfied whenever a phone passes their standard tests. So if there's a widespread problem that their (woefully inadequate) tests fail to detect in the first place, they just automatically declare victory.
Where do get that someone is creating a massive conspiracy? The guy posted he had an issue and asked if anyone else does. Some of us were able to duplicate it.Stop trying to start some huge conspiracy about how there is some major problem with the camera in these phones. I do not have this issue and by duplicate I mean yes I did exactly what he did and it does not happen on my device. you got a bum devices get it replaced. those things happen when there are over 10 million that have been sold. you will get a bad device every so often. it's happened to me. I didnt go in a forum and try and convince every person who can't duplicate it, that it's actually there.
Can you post the video? Would be good to see. Not sure why you are getting all bent out of shape though. I didn't see anyone say anything about a conspiracy.Stop trying to start some huge conspiracy about how there is some major problem with the camera in these phones. I do not have this issue and by duplicate I mean yes I did exactly what he did and it does not happen on my device. you got a bum devices get it replaced. those things happen when there are over 10 million that have been sold. you will get a bad device every so often. it's happened to me. I didnt go in a forum and try and convince every person who can't duplicate it, that it's actually there.
Nobody has said they think everyone has the issue. Again, you are the ONLY person pushing that narrative. You're bent out of shape about something only YOU have said.Forgot to reply directly to the post I was quoted saying I couldnt duplicate. person was asking if I did all the same things which is what duplicate means. apparently for some people in here it's hard to believe not everyone has this problem.
Except for you, everyone here who reports having tried the rapid trees-to-bright-sky pan says they encountered the macro-block problem. Again, it would be helpful if you could post your video for comparison.except the one guy that keeps asking are you sure you did everything like the op and the answer is yes and nothing is wrong with my phone.
